devonwoody
I want to create a new pattern arrangement for the next tissue boxes.
I want to make a template, and I thought if I got a full size template made to above pattern that I could then print, the printed pattern could then be stuck on to some timber to make a full size former that a router bearing bit could follow and make perfect cut outs. The cut out (all the way through) would then be fiilled with a contrasting strip.
I would like the pattern to adjoin all round. :roll:
The contrast strip needs to be around 3mm thick.
So is there a draughtsman with the french curves with the time please?
