Can anyone help me identify this Rail and Stile bit?
Tocaliteb
31 Oct 2020
Malmesbury
I'm trying to make some rail and stile doors with this profile . The rails and stiles are 20mm thick.
At first I thought it was an ogee style bit, but I think it's more likely to be a roundover bit but in reverse.
Can anyone tell me which router bit would give me this profile?
Many thanks.
That is unusual, I've never seen a reverse ovolo profile and scribe like that used on a door before.
It might've been done with custom spindle moulder knives rather than a router bit.
Looks the same as mine which is a standard router set, you’ll have to zoom into see it
looks to me like it was done with a rebate plane and a round
Many thanks.
That's a 'cavetto' moulding. You can get router bits eg from Wealden Tools - bearing guided probably. As has been said, you could use a half round bit after a rebate bit. Cheers, W2S
It might be a spindle moulding cutter, try looking at numbers around 136/8 in the 40 X 4 range of Wealden spindle cutters.
Trevanion and Woody - thank you so much. I'll follow up with a couple of bit manufacturers to see if they can advise the corresponding scribe (I assume an ovolo).
Thanks to everyone who helped out.
I might be wrong - I haven't tried to work it out in detail - but I think that the symmetry of the profile should allow you to use the same bit upside down for the scribe cuts.
