nev
i have a walnut bowl blank that ,after the wax was turned off, i discovered a crack/split on the centre line so i cut it in two (12 o'clock to 6 o'clock) and obtained 4 pen blanks from the centre and two (slightly less than) semi-circular pieces. i would like to use these 2 semi-circular bits with a contrasting wood (oak) insert to remake the bowl blank.
now with the oak, i love the side grain, hate the end grain, so would like as much side grain or as little end grain showing as possible.
so the question is - if i know how thick i want the side of the (finished) bowl is there a way of chopping/ stacking or aligning the oak bits so that the inside and outside and inside bottom of the bowl will be mainly side grain?:?
