Buying soft close hinges
JDW
18 Sep 2016
Newcastle-under-Lyme, Staffordshire
Hi, I'm making some built in wardrobes, doors will be 1940 x 427mm - 18mm MDF.
Weight; 11.5kg
(Will actually be less than this because of a thinner central panel - always better to over engineer...)
With Blum's guidance, I'm plan to use 3x full overlay
cabinet hinges per door - please shout up if you think I should go for 4, thanks.
6 doors; means 18 or 24 hinges but I can't find anywhere I can buy a pack of more than 2 at a time, and they ain't cheap. Can anyone give me an appreciated steer please?
Jim
I tend to get mine from here (although people have mentioned cheaper places before), you do get an extra 5% off if you are a repeat customer.
https://www.trade-hinges.co.uk/
Personally I would use 4 hinges, weight wise you will be fine with 3 but when doors get to about 2m high I tend to go for 4 (although I do overbuild things).
Video here by Peter Millard on the very subject
If you are going for soft close you don't need them all to be soft close, probably only 2 per door, that would save you a bit, personally I just get all soft close though and turn some off to keep it simple.
Thanks, very much appreciated Doug, I like to over build too - certainly better than under building(y)
Do you know anywhere I can buy them in bigger packs than 2?
I guess they don't have to be Blum/ Hafele if the quality is still good enough.
I have used Hart Wholesale in Southend-on-sea, Essex for over 20 years, even though I've now moved away from the area to Merseyside. If they will let you set up an account you have access to great advice and prices. I've used over 80 clip-on, soft close in varying combinations of inset and sit on during my bungalow refurb. Plates and hinges are ordered separately to cover 95 or 110 degree opening or varying cabinet overlay for the sit on doors. You can order any multiple you wish. Postage costs are a fixed price and reasonable.
Only problem is you will find many other things to order, eg hinges and general cabinet fittings.
https://www.blum.org.uk
Colin
I only use Blum so don't know much about other brands.
When I get them from Trade Hinges they just send the quantity you order loose in a box.
Seem to remember Isaac Lord get cheaper the more you buy but not sure what their prices are like.
I'm sure someone will be along shortly telling you the best deal available.
trade hinges are great - very reasonably priced and the order was well packed and promptly dispatched.
Trade Hinges do a ‘trade pack’ of 50 hinges BTW, pretty good value. And yes, I’d also use 4 hinges per door, if only to keep everything aligned over that height. 👍
I ended up getting Hafele 110° Full Overlay hinges (some digging tells me they are actually made by Blum) from Toolstation, 24 hinges for just over £50. I'm going to go with 4 per door because of the height as this is my first wardrobe I want to be confident the doors will stay put.
(MDF Door: 18mm thick with a 6mm thick panel, overall 1905 x 430mm, 100mm rails and stiles)
