Buying router bits
A
Anonymous
Guest
Arn't keyhole, T cutting router bits expensive! 40 odd quid!
i had a quick look through the forum and online buying guides, but couldnt really see if anyone was saying any one online store was best for buying bits.
Does anyone have a fav place to buy router bits?
Need T cutter to make the outfeed table! First major project now that I have the TS :)
DaveL
19 Oct 2002
Sudbury, Suffolk
I have a growing collection of the Perform cutters from Axminster, which I am pleased with.
They have a range of keyhole cutters but I have not tried them.
Where did you find them at £40? Does it come with a large box of the correct screws to fit the hole?
thomaskennedy
8 Mar 2004
Huddersfield, West Yorkshire
Is the slot for the mitre guage?
If so, and if they are the right size for your saw, wouldn't something like this do the job, and then you can use a standard straight bit.
You could probably find them in different sizes aswell...
Hope this helps
Ta, Tom
tim
5 Nov 2004
Herefordshire
For one offs, odd bits of moulding profiles etc for jobs I tend to use the Perform ones. For more common usage I either use Wealden or wait for friends and family to go over the pond and load up there.
Tim
jasonB
26 Nov 2004
Surrey
I agree with Tim, its hard to beat Wealden. Worth running a straight bit through first to take out most of the waste then finish up with the Tee slot cutter.
Jason
les chicken
14 Feb 2005
south wales
Might have lost the plot here :roll: .Why do you need a tee slot in the outfield table, a clearance slot will do as the mitre fence has already passed the blade.
Les
