Burnishers
Racers
22 Apr 2005
Still a work in progress, but 6 months ago I bought a small edge sharpener from a garden centre. It comes as a 4" long steel in a plastic holder, in 2 parts with a pen clip so it can be stuck into a pocket, much like a pen. It was about £10 and the maker is Burgoyne and Ball. If it matters to you the nice thing is that it is made in England.
I have been using it for all sorts of sharpening, including scrapers, and it puts a good edge on very quickly. Roll it either way and the edge is simply turned, and gives a good cutting edge to the scraper.
There must be any number of steels in kitchen knife blocks, many fairly tired. Haven't tried mine but these could function as a cheap re-cycle. If you feel strongly enough, you could clean off the ridges from say one side, with a diamond stone to give a smoother finish.
PM's replied to!
They are now spoken for.
Nice work, Pete!
That should be a tool for life - you'll never wear one of those out. The only thing to watch out for is that TC is a bit brittle - dropping it on a concrete floor might shatter it, so a bit of due care when using it might be in order. That apart, it'll last for ever.
It's extremely difficult to remove the ridges and polish metal that's glass hard.
DAMHIKT.
BugBear
Cheshirechappie":19h2t7ov said:
Nice work, Pete!
I know I have been waiting for a 1/4" end mill that I use in my router to wear out, I was going to make a burnisher with it, but I got fed up!
