Building a farm gate : Plans?
A
Anonymous
Guest
Hi all...
I was wondering, does anyone know how to build a gate like this:
http://www.chfc.co.uk/gate6p561.jpg
or have any plans or know where I might purchase a plan?
I have a fair idea of how it fits together, but always niced to have the reassurance of a quality plan...
any help would be much appreciated....
Mcluma
2 Feb 2005
Pyrford - Woking
Yep i have build one, about three years ago for my house, but have taken it away about 4 mnths ago to replace with a 2.5 mtr high electric gate
mine was 5 meter wide with one being 1 meter (walk gate) and one off 4 meter.
They do sack a bit so i put an extra support wheel under the 4 meter one.
they are very easy to build, took me about a day. but ensure the poles are about 1 meter in the ground with a lot of concrete around them. the hardware and carrige bolds are easy to obtain at B&Q
if your gates are not more than 2 mtrs in span, then there is no worry they will sack as the construction is very sturdy
McLuma
Frank D.
2 Dec 2004
Montreal, Canada
Hi Big Louie,
I built a similar 2-door gate to that one, you can see it in the pic towards the right (I also have a smaller door toward the middle). I didn't have plans so I don',t really know what to say...I just calculated the width of the opening, subtacted a little for the hinges and center and then divided by two. That gave me the measurement from each door. I then layed out the lumber for the frame on saw horses, measured the width and diagonally to get it square, then clamped the corners. Then I traced the outline of the overlapping frame members, and made the cuts for half-lap joints. Half-laps are very strong, and with a few screws and polyurethane glue they should never move. The doors don't sag thanks to the X frame like on your pics.
If you need to know more just ask.
les chicken
14 Feb 2005
south wales
Hi Biglouie
Built almost identical gates this year. Uprights and top bar 3x2 and small bars and cross beams 3x1. Horizontal bars mortised and tenoned into the uprights glued and dowelled. The dowel will increases the strength of joint. The cross members a sort of half lap joint to keep flush and then bolted with coach bolts. Made out of tanalised wood and then sanded and stained.
Les
A
Anonymous
Guest
Les
Did you just design from looking at another one? Or grab a plan from somewhere?
I might just go and draw a plan up from someone elses gate..
Dont mind me!
Just copying the design fo your gate love....
Burglar?
No. Just a bit odd.
A
Anonymous
Guest
Frank...
Nice gates...very tidy.
Not what I had in mind, but it's got me thinking now. Maybe I'll speak to the wife, see if she wants to rethink her plans..
les chicken
14 Feb 2005
south wales
Biglouie
I was asked to replace some gates that were falling apart. Virtually identical to the ones in your picture. The way they were made was pretty poor, butt jointed and screwed. So decided to make with mortice and tenon and dowels.
Les
