Picalilli
Hi all,I’d like to get a bench grinder for doing the occasional re-establishing of primary bevels, but also want something I can attach a wire wheel to for cleanup of old tools etc as I do a lot of that.
I’m looking at either the titan from Screwfix or maybe one of the Axminster craft ones (links below). Is the Axminster one worth the extra? It seems to have a less powerful motor which is often a bad sign, but maybe better for what I need?
Any advice, as always, much appreciated!
don’t want to spend a fortune but might be able to push the boat out if really worth going for something slightly higher priced
www.axminstertools.com
Axminster Craft AC150BG 150mm Bench Grinder
Perfect for the home workshop, this 150mm bench grinder is quite a neat design. Fitted with twin 20mm wide 80G and 120G white stones, it is perfect for light sharpening and re-shaping tasks. The standard white stones don't create high temperatures, so...
