Trebor33
My clarkes table saw blade will not turn although the motor is running fine and the nut on the blade is tight, when I say it will not turn it spins freely by hand ,any help thanks.
No drive belt ,I was thinking it could be bearings on the arbor ,not sure, any help would be appreciated, thanks.Harbo":16r30jwm said:Has it got a drive belt - could be broken?
Rod
Trebor33":n1ba7jzg said:No drive belt ,I was thinking it could be bearings on the arbor ,not sure, any help would be appreciated, thanks.Harbo":n1ba7jzg said:Has it got a drive belt - could be broken?
Rod
It is model cts10c ,thanksStanleymonkey":1sm0vr90 said:What model is it please?
No spin on the shaft and the motor is running OK,NazNomad":2z26nsz4 said:Take the blade off and run the motor ... does the shaft spin?
Thanks, I guess it's time to look for a new saw but not a clarkes, thanks again .Myfordman":38pp7iw5 said:The gearbox has failed. Beyond economic repair as the gearbox comes with the motor.
Like most Clarke products it is a heap of ........
