Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 74
I mulled over all sorts of alternatives. Initially I thought I couldn't fix it, then I thought I should replace it with an Allen bolt (to tighten down on the clamp, which was undamaged). It tried glueing it with super-glue - no joy.
Then I had a brainwave:
It looks a bit like some sort of monkey! There are four holes, M3 tapped (the pic isn't good)...
The bolts weren't staying like that...
They were epoxied in place, then the heads were cut off with my trusty Proxxon (Dremel-ish) mini-cutter.
Now they fit either side of the web of the handle, and cross the break by several mm:
It was temporarily tack-glued back together by dipping the broken end in epoxy. Then the space either side was filled up with epoxy, round the bolts, which now act as reinforcements:
I think it's good to go. I'm leaving it overnight to fully harden, the reassembling the fence tomorrow. Phew.
Pics from the camera on my new Galaxy Note tablet, incidentally. I was surprised that it actually can focus that close. I think a couple are slightly too close, but I'm quite impressed at the quality, considering.
Posted in case someone else is muttering darkly, as I was when it happened!
E.
