woodbrains
Hello,
Is anyone familiar with the router plate for the Bosch guide rail system? It states in the description that there is 25mm of lateral adjustment. Now I'm thinking this set up could be great for routing housings, BUT if the cutter cannot be adjusted so it kisses the edge of the guide rail, I don't see the point of it at all. In the photos I see on the Axi website etc, there looks to be a space between the routed groove and the edge. I would want the set the edge to a marked line and route to that line, just the same as the tracksaw cuts to the line. Otherwise positioning becomes a nonesense because of the offset and I may as well use the methods I've employed before. I have the guide rails, so potentially it could be useful. Any thoughts?
Mike.
Mike.
