DiscoStu
I'm sure you guys are probably aware of this, but I just came across it and found it to be quite exciting!
I was looking for some software that would help calculate the best way to cut boards to optimize the use of materials.
I came across this site:
http://www.optimalon.com/online_cut_optimizer.htm
It worked brilliantly
The only very minor issue I had was that I had to set up two boards, one with 2440mm as the length and one with it as the width and then it calculated the cuts. It takes into account the Kerf and even wastage on edges etc. etc. It even gives you a list of all the off cuts you'll end up with!
Very easy to use.
Here is an example:
Very easy to use.
Here is an example:
