Morning all - I'm adding a door to my router table. It'll be a bit of Duropal, backed if necessary with some ply to add thickness (the Duropal is I think 10mm).
I have two Blum thin door hinges - specifically these 'uns:
www.trade-hinges.co.uk
The vertical panel in the router table is inset a bit, so I assume I'll need to add in a hardwood thingybob to give me a mounting point that's in line with the door opening. What I'm not clear on is how I make sure I've got the hinges in the right position on that so that the door closes to the position I would like. This is probably blindingly obvious to anyone who's ever done it, so some pointers would be most welcome. Happy to post photos if that'd help.
Thanks in advance.
Blum Thin Door Hinge
NEW Blum thin door hinge with integrated soft close, impressively easy to use on doors 8 to 14mm thick. Assembly is simple in just a few steps,
Thanks in advance.
