Blum Ecodrill Users - other cutters beside the 8mm available
mickmick
New member
18 Nov 2018
london
Just bought an Ecodrill and seems well put together.
However I am disappointed to find that there don't seem to be any other cutters/drill bits available other than 8mm?
I am not sure about using the Inserta hinges that the 8mm holes are designed for. Do they hold up to being installed and then being uninstalled? Perhaps in a dry fit situation, or where something may have gone awry and needs fixing?
Ideally I would ideally like to just buy some 3mm drill bits to create pilot holes for normal screws and standard Blum hinges.
Has anyone found a workaround?
oakfield
7 Oct 2009
East Sussex
If you keep the collar on them you can use the centre point of the drill to mark out for the screws - I just screw into these marks without pilot holes.
