Bleaching wood
Mike MW
9 Apr 2021
Tq109aw
I would be grateful for advice on bleaching wood . I tried household bleach with limited success . Ideally I would like to achieve a drift wood effect but marked lightening would be helpful.
Jacob
7 Jul 2010
Derbyshire
Caustic soda dipping produces the driftwood effect very easily. Not to soak for too long otherwise you could destroy it, starting with removing glue and loosening all the joints.
You can just brush it on, leave for a bit, and hose it off.
Richard_C
17 Oct 2019
Cambridge
I tried bleach on a small sculptural project, as you said not that effective. It wasn't going to be handled,and I wanted to get the effect with what I had in so I ended up giving it a thin coat of diluted ordinary white ceiling paint, let it dry and sanded back. When happy, a wax finish. A decent enough cheat, but doubtless there are better solutions.
Mike.R
23 Apr 2014
yorkshire
Hello Mike, I asked here on UK Workshop about wood bleach back in June this year as I was interested in bleaching oak. The recommendation was to try Oxalic acid crystals and a two pack bleach from Fiddes. Neither of which I've got round to trying yet. :rolleyes:
Here are some links.
Bleaching wood is added to my list of things to do this weekend. :)
Stigmorgan
18 Aug 2019
Ash Vale, Aldershot
Have you tried YT? Pretty sure I've seen a video that included bleaching wood at some point in the not so distant past
jonn
22 May 2015
Norway
Thanks for reminding me of the name for oxalic acid. Used it close to 50 years ago to bleach the pine panel in my lounge room. Very efficient, and found a supplier here in Norway who sells it at a fair price.
Jake
5 Apr 2004
London
The two component peroxide will not in my experience give you driftwood - it will give you a OK fade but will not 'bleach blonde' well at least with the things I've tried it with. It goes to a pretty gross yellowy-tinged result and then stops (or rather, the surface starts falling apart, while also being gross and yellowy).
