Bleaching Sycamore
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
I am making some cupboard doors from ripple sycamore (well luckily I discovered the ripple when dimensioning the waney boards), and they will be place in a narrow hallway that is a little dark, so the whiter they are the brighter the place will look and the further back they will seem - that's my wife's logic who is much better as these things than I am, so I listen and do likewise.
The question is how to make the sycamore whiter, bleach I guess?
But how do you do it?
A rag with domestic bleach and see how it goes, then a little more, then a little more till the white is just right, then wash it out with water?
Or do I need some industrial strength stuff - if so where does one procure such stuff etc etc
Or is lime waxing the way to go?
Once again thanks in advance :wink:
Hello Andy,
I use the Rustin's bleach a lot on wet turned sycamore, using colour in my work I like to start off with as white an item as possible.
Simple, easy to follow instructions on the packs, "works for me" as they say.
Regards....CC
