-Matt-
Picked up a RP RSBS10 at local auction yesterday to compliment a seemingly ever growing collection of machines.
Two things of note. The table was showing a good film of surface rust and other marks (including dried on glue.. why?!) as well as missing a guide roller.
So, doors off, table off:
(All clicky for larger if required)
Took the table outside for a liberal poking with the wire cupbrush on angle grinder:
Now the roller. Its in two parts as it were. There's the little bearing that the blade runs against and there's a small piece of 10mm dia bar that sits in a channel with a threaded hole in it. No problems, bit of 10mm stainless that I had, hole drilled and tapped M5... and the bearing? Well because I have a habit of "That'll come in useful) I happened to have the sliding door roller mechanism from a Transit kicking about. Same size too! That was duely installed:
Clean table back on:
Back together:
On the phone to Tuffsaws next for a few new blades, put together a stand for it (I have a location earmarked for it to live) and I'd say its good to go
Thanks for looking
-Matt-
Back together:
Thanks for looking
-Matt-
