Best way to sand curved edges 6mm plywood to match template?
Peter029
New member
19 Oct 2012
United Kingdom
I'm wondering what the best way is to do this.
My method is to use a printout stuck onto plywood, then cut closely with a bandsaw. The next step i've tried was using a small dremel kind of minitool which has a very small drum sanding attachment. I'm finding its not really a very good tool to edge up to the paper template edge as the radius of the sander is small.
I think ideally i'd like something like a concave belt sander, on it side. Is it possible to get anything like this or can anyone suggest a better way for me to go about what im trying to do.
Thank you.
Clamp a belt sander on its side and tease the ply up to it. Finish by hand with a sanding block.
