Indeed, I could do with a dust extractor
I plan to get a proper Pentz system, or similar, and it will serve me well.
I don't use the saws much at the moment, but when I do, I get suited and masked up.
I tend to do a lot when I do use them, and leave the dust to settle after.
I use planes mostly so the dust isn't bad.
This is only temporary.
Dust extraction on the machine is a matter of cutting a hole in the saw
On the Startrite, it would not take long as its a biscuit tin underneath.
The arbour is mounted onto the table by one trunion only so, theoretically
the blade could nip away at the zero clearance insert in some cases.
I have not found much movement in the blade I must admit, but when the blade is tilted I
noticed some skewing on something ...
I will take a piccy and do some tests on this sometime as I keep waffling on about this,
I can't now for the saws are tables for the lengths of this bench build at the moment.
About the crown guard ...
I'm looking at getting some correct plastic for the job...something like a clear HDPE
and using this plastic as templates.
Some other wee bits of this system need some work also.
And the 14" blade part I've heard this from another member, and don't have a 14" blade,
The riving knife mounting is cast into the trunion mount and is very easily adjustable though.
I would take a guess, my riving knife may work for a 14" but if not, I could just make another.
I advise the OP to get one of these and an extractor as you really get filthy.
I have overalls that are covered front and back.
I did hope to get a proper boilersuit which I found, locally... but not in my size.
I had to ring them up, paid a lot for it (75 quid), and got screwed over by the O'Connor Group Limited Demesne, Newmarket, County Cork company
who sent me a very different, inferior boilersuit, and denied the garment I had tried on a month or two earlier existed :shock:
I couldn't send it back as they only delivered it to a farm shop far away, and I had to pay postage.
I was on the phone to them and they blatantly lied and lied to me..
What a shower of ....
I have sourced some other parts for my diy respirator since, and will update that thread when I get round to it.
Tom
