Best practice wood?
Duiker
4 Jan 2005
Uithoorn, The Netherlands
Hi people,
What wood do you recommend for me to practice on? I need something reasonably cheap but easy to turn (if such a wood exists?).
Cheers,
Mick
Taffy Turner
24 May 2004
The Land of My Fathers
Mick,
Sycamore is easy to turn, and cheap(ish), Ash is good as Chris has already mentioned, Beech is also a nice wood to turn and is reasonable, or I have recently discovered London Plane is a dream to turn, and again is not expensive, and has a very intersting figure to it.
Most native woods would fit the bill, with the possible exception of Oak, which I find a bit more difficult to turn, and it blunts the tools quickly!
Regards
Gary
A
Anonymous
Guest
I think that Sycamore is the wood DC uses in his planing classes because it planes so well. Never tried it myself. I highly recommend Ash
jasonB
26 Nov 2004
Surrey
Also worth having a try of some green wood, you can usually get it free from tree fellers or your local woods. Need to be patiant and wait for it to dry after rough turning or learn to turn it very thin so it dries as you turn. It is also much easier to cut.
Jason
trevtheturner
26 Feb 2003
Herefordshire, UK.
Hi Duiker,
If you are looking to practice purely to develop your skills I would recommend using a softwood such as pine. Because it is a softwood the grain will tear very easily. Your chisels/gouges need to be sharp and then when you can produce a good finish on your coves/beads/fillets, etc. on a softwood you will know that you are using the tools correctly. You will then be able to apply the same principles to any wood with satisfactory results. Pine is cheap enough (and often found in builders' skips) to practice on and then discard. Save the expensive hardwoods for making things when you have your skills - plenty of practice and it won't take you long :wink: .
Cheers,
Trev.
Duiker
4 Jan 2005
Thanks people,
Bought some bits and pieces at a local timber yard at the weekend. The guy had these spindle blanks almost as scrap. bought about four meters of hardwood for 10 euro's. Not too bad and good for practice too.
I like the idea of using pine for skills though, didnt think of it in those terms.
Thanks again all,
Mick
