Has any one ever Re-sprayed or re-painted,their Union Gradute Lathe? I would like to know what is the best Product and best method of giving my Lathe a facelift? I have only acquired my lathe today.
Kindly Paul
Kindly Paul
Thanks for you help,do you wire brush away completely all the paint on the lathe? right down to the bare steel?then start to re-paint !flh801978":1m0751wh said:Paul
I have given the whole machine a wire brushing with a hard wire brush in an angle grinder
then with a flap disc sand any large chips away
then with a small foam roller ( 25mm dia and 100mm long )paint with hammerite ....repeat and its done
Can you get QD90 in various colours?phil.p":2crts9qx said:QD90 is thought by many to be a better paint than Hammerite. Worth a look - it's often cheaper as well.
Jamie Copeland":2qe25zjy said:Hi Paul
I painted my Union graduate with Hammerite hammered grey paint. It looks great when finished.
paulkane1":h4eajmnh said:Jamie Copeland":h4eajmnh said:Hi Paul
How much take it take to cover your lathe? It's averaging about £9 for 250 ml,over £40 a Litre ,which I don't think I need,Maybe 2x250 ml tins?
Paul
Thanks a lot for the link. PaulJamie Copeland":5k17xtpe said:paulkane1":5k17xtpe said:Jamie Copeland":5k17xtpe said:Hi Paul
Paul
Hi Paul
I bought one 250ml tin which covered the lathe, but I had to buy another 250ml pot to do the tail stock, etc.
Two 250ml pots will be plenty.
I've had a quick look and found a site selling it - Wigley DIY. Two 250ml pots of silver hammered finish comes to £10.56 and postage is 3.95 so £14.51 in total.
