Best fixing for bath panel?
phil p
29 Feb 2008
Hi,
As per the title.
I'm going to try and fix some sort of frame under the bath to accept the panel and was wondering what would be the best type of fixing to use where I can just pull it off should I ever need to access the pipework.
Unless anyome has a better idea on how to fix the panel on in general without a frame?
Regards
Phil
Sawdust=manglitter
14 Feb 2016
Nr Cross Hands, South Wales
I used pipe clips attached to the bath panel and put 10mm dowels into the sides of the frame so its easy enough to pull off if needs be but firmly holds it in place.
deema
14 Oct 2011
chester
Just a thought, with very few exceptions, a ‘plastic’ bath needs a frame to ensure that when someone sits on the edge it doesn’t split the bath edge.
phil p
29 Feb 2008
Thanks for the feedback guys, all very good suggestions as usual.
Regards
Phil
Bm101
Lean into the Curve
19 Aug 2015
Herts.
Regards
Phil
In that case.
Tiny unemployed dwarves. Like normal ones but even shorter than normal. And generally unemployable cos otherwise wages are going to be extortionate. Also when you're having a bath you could have conversations pretending you are daft enough to have one of them home hubs like Alexa so instead of proper corporate spyware and algorithms predicting your spending patterns and political allegiances you could have a fake harmless one but not feel like you are being left behind in a technological sense.
You'd be in the bath and go, 'What's the weather tomorrow Barry?
*Muted response* Well it's quite dark in here but maybe it will be sunny?
*Thankyou Barry.
You could drop a peanut or two down the food hole.
"What's the traffic like on the North Circular near Leyton?"
*Tremendous? ...*shrugs*
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
I'll have a pint of what you're on...
I've not done velcro but I have done magnetic catches. The latter work well and I would expect velcro to work just as well.
