Best Finish For Walnut
thecoder
24 Apr 2011
Pontefract
Hi folks im just making my first box out of waknut and have not got a clue how to finish it.. #-o
Can someone please advise the sanding process and reccomended finish please.
regards
Dave
Hi Dave - not spent time with waknut (very sorry, my humour gets me into trouble often :oops: ). it's a beautiful wood, very fine grain and gets away with minimal finishing (esp. on a box, which will not suffer heavy handling.) personally I'd go for a light natural oil - applied very thin and left a while, then buffed up. Not widely accepted but natural oils are actually finishes, being capable of hardening off and taking a soft sheen - ideal I feel for walnut, will allow the grain and depth to really show. Whatever you go for please avoid glossy synthetics... your walnut deserves better then that.
(edit) sorry, missed the sanding bit - this is very personal taste but I try to avoid sanding at all. If you can get the surface you want off the blade, skip sanding. If you have to sand, then brush all the dust out after - sanding makes things feel smooth, but mainly cos they are clogged with dust, which truly challenges any later finishing as the dust turns grey. For final finish consider a well-tuned cabinet scraper?
[have a funny feeling I'll be in trouble over this 'advice'... we'll see]
if you are using American Black Walnut try this,
prior to applying finish wipe the walnut with Behlens lemon yellow solar lux stain. if you then use danish oil it really brings out the colour of the walnut without making it yellowy!
try it on a scrap piece you will be amazed, i was the first time I did it on recommendation.
Rog
Hi Douglas,
Yep Waknut is very similar to walnut :D :D :D
Rog
Roger im not sure if its AW or nut all I know is its walnut #-o
thecoder":hibdz5ev said:
Cheers guys
Dodge, is the stuff you mention widely available
Dave
You can get it direct from Behlens
http://www.behlen.co.uk/Merchant2/merch ... Code=DYEST
A small bottle goes an awful long way as you are only lightly wiping it on - it dries in about an hour and I think you can use pretty much any finish over the top - when you first apply the walnut appears to go orangey in colour but then when it is dry and you apply lacquer or oil the depth of the walnut colour is really enhanced.
Rog
Dodge":3neql9fa said:
thecoder":3neql9fa said:
Cheers guys
Dave
Rog
Cheers Roger, I have set pieces of maple keys into the mitres, would the stain have a negative effect or just enhance it.
To be honest havnt tried on any other woods - if you pm me your full name and address I will put a small amount in a jar and send it to you so you can give it a try on an offcut if you like.
I've got to go to the post office tomorrow anyway
Rog
Rog
Very kind of you Roger. Pm on way.
Sand to a minimum of 240 grit (higher if poss) and Whatever oil you use finish with a coat of wax when the oil is dry.
Andy.
