Best buy so far this year
pops92
10 Oct 2016
Boston Lincolnshire
After looking at the Axminster,Record and Kreg update I decided on the Kreg for my BS350. This was not on price as that wasn't an issue. The ease of fence removal not the guide was what I wanted and this as worked great for me.
Taking an extra couple of minutes to change the blade I didn't see as a problem. The instructions on fitting the fence guide are no good as they are different machines to mine. I used non of the mounting holes pre drilled.
I set it up were I wanted it as shown and used sash clamps to hold position, set a 1/16" below the t slots. Drilled pilot holes through the fence and the bed. Then 6 mm in the fence and 5 mm in the bed this is a 6mm tap.
Clean the holes and threads and good to go, as you are using a 6mm hole and 6mm bolt there is no slop.
I have done 4 blade changes up to now and now need to anything its spot on.
