Bessey KBody clamps
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
I'm thinking of investing in some of these, thing is, how parallel are the faces? Obviously when the clamp is tightened then the bar has to bend a bit. Not much, maybe, but a bit. When the bar bends, then surely the faces won't be parallel anymore? Anyone know any different?
Noel
Moderator
Staff member
Moderator
7 Aug 2003
FWW did a clamp road test a few issues ago. The K Bodies came out tops. A test bed was used to measure beam deflection.
PM me for a copy if needed.
Noel
Shadowfax
1 Nov 2003
East Sussex
I fully understand your reasoning and cannot argue with it but I have been using these clamps for quite a while now and I can tell you you need not worry. If the faces are not parallel under load then it must be practically impossible to detect the deflection.
K Bodies are awesome in use - heavy but so easy to use and as far as the faces staying parallel I have never noticed any problem at all.
You should find them a real bonus.
SF
