Bench top router table laminate
Born2bye
12 Sep 2016
Telford
Hello all
i am thinking about building a bench top router table, many of the online videos show people bonding a laminate or Formica type material to their top, any idea’s please on where this type of material can be purchased in the UK
thanks
TRITON
5 Oct 2014
Sunny Glasgow
That phenolic stuff is usually quite pricey. I covered my extended bandsaw table and drill press table in Formica laminate sheet.
Been a while since i bought some and thought its not cheap usually(Still about 1/2 the cost of phenolic), you can usually find it in 4'x2' sizes or offcuts(dependent on you knowing what size you need) for a fair bit cheaper.
On the bandsaw table i made to increase the table area, i used a slightly textured surface as its less friction. But I've no idea what that is called exactly.
Best fixed with evo-stik 528 industrial. Though standard evo-stik impact contact adhesive is probably just as good, and its best to use something like a seam roller to get it stuck down hard.
Pedronicus
4 Jan 2022
Surrey UK
I found an old Formica covered ply kitchen table on Freecycle which I will be repurposing for my router table in due course.
Jones
5 Oct 2021
Gwynedd
You can use a contact adhesive for Formica and you need to on verticals but on the flat a resin , either epoxy, resorcinol or urea formaldehyde makes it a much simpler job and you get time to do it right. Standard sheet is 1.5x3.0m ,there are cheaper imitations and I'm sure a search will find people doing smaller pieces.
GrahamF
11 May 2015
Abergele and Portugal
I bought some Formica on ebay recently, available in various sizes. Used Evostick solvent free contact adhesive, easy to apply evenly by brush or roller.
alan895
8 Dec 2012
Hampshire
For mine I used a free offcut of kitchen worktop but even just a simple piece of MDF or plywood with some sort of protective finish applied would likely do the job.
Johnwa
18 Dec 2019
Wolverhampton
I made a router table for my 1/4" router. I just used melamine faced chipboard, it's been going fine for about 2 years now. Kept in a cold, damp garage no sign of warping or twisting and the timber still glides across the surface.
Distinterior
8 Mar 2014
Colchester, Essex.
I've got quite a few sections of 38mm kitchen Laminate worktop offcuts that you could choose from,.....but I'm a bit far away from you!!
I think the minimal lengths I have are 1000mm.
baldkev
29 Apr 2020
devon
I bought a couple of sheets of 12mm phenolic ply to reboard my tower scaffold, worked out about 50 quid a sheet.... so by the time youve bought formica, glue and messed around, you might as well buy phenolic.... at least phone around locally and see what you can get. Tell them you are trade 🙃
