Has anybody else tried this?
I got a new acquisition yesterday - a nice little Clifton No3
The guy had described it as "hardly used" - and he wasn't wrong! Looks pristine (still has the green hue on the brass fittings, for those familiar with Clifton planes).
Anyway, i'd seen that Lie Nielsen sell a "90 degree scraper blade" for their LN 62. Bit more digging about reveals that this is just a blade with a 90 degree "bevel" - ie no bevel.
So why not try increasing the effective pitch of a bench plane to 90 degrees (or beyond) to give a scraping action?
Taking the fresh Clifton blade (i'm about to order a replacement for normal planing, so worry not) I mounted it at 45 degrees the wrong way round in the eclipse guide
And then proceeded to sharpen - as this was the initial hone on the back (or face if you prefer) of the blade, just a few wipes on the fine stone, with a bit of stropping with some fine honing compound. The wire was removed from the bevel side freehand.
Once the plane was put back together, tested it out on some scrap beech - just to get the feeling and test the depth of cut
And then onto the serious stuff - a piece of Cocobolo. This stuff had been prone to tearout at the drop of a hat, and needed a high EP to give a clean finish.
As you can see, proper shavings were the result, leaving behind a nice glassy tearout-free finish.
Hope this little experiment is of interest to some others out there.
Karl
Karl
