Bench Hook(s)
Orraloon
18 Oct 2016
Blue mountains Australia
I am sure the guys that bought the winding sticks would want one of those too :D
We dont need to have the how we spend our money discussion again but seeing that you have to wonder what some woodworkers do in the shed.
Regards
Chris152
26 Apr 2017
Cardiff
You're probably right, but I guess they're aimed at the 'present for someone special' market rather than something you'd buy for yourself? I know I'd rather those than socks and pants at Christmas.
ED65
3 Dec 2015
Like Phil I've never understood why anyone who has aspirations to be a woodworker would buy one of these. Maybe it's because they haven't seen a how-to on how to make one :twisted:
Jokes aside, bench hooks have actually been available as commercial products for a long, long time so it's not a recent phenomenon.
Stanleymonkey
15 Jun 2014
South West London
£75.00 - bloody hell!
You might think £20 for a pair and it would make it worthwhile for someone to have a couple of pairs ready to use when their current bench hooks pack up. But you can hardly justify saving the time it takes to make one by spending that much.
woodbloke66
17 Sep 2018
Salisbury
My thoughts exactly; these things are 'shop made jigs from offcuts loafing around and they get pretty severely chewed up after a few months. £75 is having a larf :lol: - Rob
13 Jul 2015
Wales
There are for people who put sacrificial sheet materiel down to protect their workbench top.
SMALMALEKI
30 Jan 2018
Derby
Thank you for starting the thread
I use the opportunity to ask some stupid question.
I have made my own shooting board for both 90 & 45 degrees. After struggling for few days I realised the angles were not accurate.
Therefore without having a reasonably accurate reference it is a challenge to make jigs for an accurate cut.
I would love to learn some tricks please.
13 Jul 2015
Wales
I too tend to go the adjustable route, I think it's easier. No farting about with glue and screws. Basically, you just attach the stop with a nut and bolt, where the hole for the bolt is a mm or so larger than it needs to be. Giving you a bit of play.
Here is an example, but I would just have it be secured with sunken bolts, so it doesn't get in the way. You're very rarely going to adjust it.
SMALMALEKI
30 Jan 2018
Derby
I have made the same one. My square was not square enough first time. That was the main cause of it being out of square.
Then I used my old school memories to draw accurate angles.
SMALMALEKI
30 Jan 2018
Derby
I like the shooting board but the plane is even more interesting.
woodbloke66
17 Sep 2018
Salisbury
I've made loads of shooting boards over the years and this is the best one I've ever seen. It's simple, adjustable, easy, cheap to make and it works. Change the block or fence at the end and you can quite easily shoot 40mm square oak as I did recently - Rob
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
+1 for the Tim Rousseau board. Mine is constructed like that, but not as long, I still shoot across my bench rather than along it. Plus my plane runs on an UHMW strip built into the board. But the block sits on a low key like that and is easy to set and adjust. I also find it a good idea to have the RH end of the block cut back by a couple of degrees, rather than being exactly 90. The workpiece is still supported properly, but the plane doesn't have to fight with the block as well as the workpiece, it just makes it all a bit easier.
rafezetter
Troll Hunter
11 Jun 2013
Bristol
Still prone to movement, especially if you are prone to letting the plane blade go past it's useful edge and applying more pressure than needed to shoot - I prefer the method of securing one end with a screw so it pivots, use a square to "sort of" set it, clamp the other end, grab a bit of thin ply a few inches wide (at least, wider the better)and use the shooting board checking the angle against a machined square (lots of places to find a machine set 90 deg if you're not 100% sure of your actual tool square), and refine the stop angle until it's bang on 90 deg, screw in the other clamped end and enjoy.
My shooting plane is a wooden badger plane (skewed blade) with a section of UHMW sheet screwed to the sliding face to raise the side and give a slippy surface...
