Bench Grinder
SteveF
16 Sep 2013
Maidstone
Hope this not been covered and I just cant find it
i bought new axminster grinder today
the cheap one :oops:
the tool rests look inadequate......................don't really lock up tight and a bit small
anyone built some new ones...maybe attached to bench instead of the grinder....maybe with a built in protractor ? :D
Steve
looks interesting
i will need to look at fitment
i was thinking some angle iron and some adjuster thingy
but not adverse to aftermarket if fit possible
Hi
I think Keith Rowley shows a home built grinding rest in his book - there are also lots of similar versions on the web
Regards Mick
    252.7 KB
    218.5 KB
I was going to mention Keith Rowley's rest/jig too when I saw the opening question, beaten to it :)
He gave full instructions, cutting list and the works in his book, Page 40.
I've ended up going for Tormek brand bought ones, as I've got a worksharp, and other than attaching the whole machine to a board mounted at 90 degrees, I couldn't figure out how else to use a jig like his. I wasn't sure how the motor bearings and stuff would react to that, and I know all the jigs etc that I've bought will work on other grinders and sharpeners if I decide to change in the future, so no harm done.
I've welded the rests in the extreme furthest away position on my Clarke bench grinder. I've drilled and tapped two holes in the original rests and fitted a countersink slotted aluminium plate to each rest. I found the original rests too small.
I've also got drawings to machine up some angled rest blocks and a drawing for an adjustable angle rest block, I've just not gotten around to having them made.
i had a read of rowley jig
i think i would prefer a metal one
i would be interested in the drawings u have
i have some bits of steel laying around atm
I'll drag them off the workshop PC tomorrow and PM them over to you :)
