bench grinder advice
I have a 250w Clarke one for sale, £10. The wheels could ideally do with replacing but could be dressed down if you're on a tight budget. It's up in Blackburn, I should be back up there at some point in the next week or so.
Hi
It will be fine, (basic but fine :) ), for what you need if you are prepared to make a dedicated adjustable rest and a fingernail jig, ( dead easy and plenty of plans and examples on t'internet).
It has limited 'upgrade' potential due to the wheel thickness - I'd consider 16mm to be rather thin and would suggest trying to get something with the capacity for wider wheels, (25mm if you can).
Regards Mick
