Belt sander or random orbital sander
JFC
30 Sep 2005
London
I normally use a belt sander to finish my work and clean up any joints but i've seen quite a few joiners using random orbital sanders . I used the random sander to finish a parquet floor once and it gave a nice finish but was slow . Also a friend of mine once used a random orbital on a table top and it left little circles all over it .
What say the forum on what sander for the best finish ?
Philly
24 Nov 2003
Dorset, England.
JFC
I have a Metabo Duo ROS-it has a dual orbit (3 or 6mm) so can remove material very quickly AND leave a perfect finish. I'd definitely have a look at one-I find the belt sander a little "agricultural" in comparison.
Hope this helps
Philly :D
Gill
3 Sep 2003
Lincs
It's probably not as snazzy as other ROSs, but the B&Q sander discussed in this thread is proving to be an absolute gem. It doesn't get used every day, but it's certainly getting worked and it produced a lovely finish on my recently made maple table. For less than £20, I'm very happy with it.
Gill
JFC
30 Sep 2005
London
philly i have the same metabo duo sander , maybe ill try it when cleaning up my next job , im just a little worried it will leave the small circles i mentioned . Its the same make sander my friend used .
p.s philly is that a record 120 block plane as your avatar ?
Philly
24 Nov 2003
Dorset, England.
Give it a go-don't apply much pressure and you'll get no swirls.
And it's a Lie-Nielsen 102 block :wink:
Philly :D
frank
10 Sep 2003
cheshire
jfc what is the final grit that you used and does you sander have a speed control ,one of the members said the slower the speed the more you take of ,i find this works for me .
frank
Der_Goalie
4 Oct 2005
It won't leave any swirls, as it is fitted with a rubber brake pad which stops this happening.
Bean
12 Jan 2004
scouting about
ROS is the way to go, but belt sanders if used carefully with the grain can be good. But there is a high risk of catching an edge which will leave a deep score mark.
My favorite is a good plane with a fine cut..............the wood glows
Bean
