I have a scheppach bts 900x belt and disc sander the motor is ok but I have to hold the start button in to keep the motor running could anyone advise what is wrong.
Sounds very much like failure of the relay in the no-volt release switch. You may well need to replace the switch - they are available as spares though not all that cheap.
Has this worked in the past? I bought a new machine and the switch was wired backwards.
If it used to work but just stopped, then a new switch is what you need.
I've had to replace the start capacitor on my B&D sander but lately the switch is reluctant to latch sometimes.
I'm wondering if it would be better to just fit a toggle switch when the contractor eventually fails?
Check you have good connections to the switch. They usually fail completely rather than go intermittent. Even a loose wire in the 3 pin plug would give that symptom.
