Bearing install PT255 ( cutter block )
John samson
6 Aug 2020
Chelmsford
Hi.
Just wondered if anyone can help? I’ve purchased a second hand PT255 and have stripped it down.
The cutter block bearings required changing as I believe the machine is about 40 years old.
I have tried to find Nigel or Karl’s posts regarding the rebuild of their PT255 but cant locate.
I had thought about fitting the new bearings on the shaft and try to locate in the remove cast side panel which with the weight of the components is not easy!
Many thanks
John.
