andrewm
OT since no woodworking involved but I know that a few people around here install bathrooms so might be able to help.
I have just installed a new bath screen. I believe it originally came from B&Q although I picked it up unused and second-hand. There is very little in the way of installation instructions. It is of the type that has a small fixed panel and a hinged door. The door being hinged at the top and bottom instead of on the face. The bottom hinge piece looks like this:
The circular piece is screwed into the end of the aluminium extrusion holding the door. The bottom piece is fixed to the fixed pane. The raised bits act to keep the door closed.
Now, the problem is that there is not a tight fit between the fixed and moving parts. This looks to be by design. However this means that there is a path for water from the shower to get into the hinge on the shower side around the circumference and out the other side. It looks like there should be an O ring around it but the gap is too small and I would have expected a groove around the moving part.
Has anyone any experience of this type of design and if so can the tell me if it is an inherent design fault or do I have some bits missing. What would be the best way of making it watertight. PTFE tape stuffed in the gap?
Andrew
Andrew
