phil.p":1y439jv0 said:https://www.aldi.co.uk/workzone-electric-band-saw-350w/p/013419269282600
is the same saw iirc.![]()
Distinterior":12q8jc6z said:I cant speak for either the Aldi or the ITM bandsaw,.....But that Titan model from Screwfix is truly dire..!
I purchased one in a moment of madness a good few years ago now and it really is not fit for purpose. It's been sitting unused for years now in the back of my home workshop collecting dust....a complete waste of money!
Distinterior":1yuaed4u said:I cant speak for either the Aldi or the ITM bandsaw,.....But that Titan model from Screwfix is truly dire..!
powertools":1ojf67q1 said:Distinterior":1ojf67q1 said:I cant speak for either the Aldi or the ITM bandsaw,.....But that Titan model from Screwfix is truly dire..!
What were you comparing it to at a similar price?
Simon_M":24wateei said:I have two bandsaws. One is for sale and the other is new as well as being bigger.
My experience is that power can be measured in three ways. There is a power rating that is the normal power in use, sometimes called S1 (or P1) and there is S2 (or P2). The latter is the power under load that can’t be maintained. For a bandsaw, that’s OK because we use it infrequently with a mix of other tools ( probably).
There is also the output power e.g. the same machine (sold by different sellers) may be rated 750W or 3/4HP which is 550W. Or 250W or 350W. The difference is if it’s input power or output power so both can be correct. Marketing people prefer the bigger number but the buyer looks for output power.
As an example Axminster have their first Trade lathe catalogued as 750W. However, the machine plate shows 3/4HP (550W). The catalogue quotes the input power and the motor lists the output power. Buyer beware.
It’s not all bad, because a bandsaw needs three things:
1. A user to setup and operate it correctly
2. A good blade
3. A good fence and table
Notice I didn’t mention power because for many tasks it’s not too important and because a bandsaw operates with 3-24 teeth (ideally) 6-12 teeth in the workpiece and this is much easier than say a table saw blade where there is a lot of friction to overcome.
If it’s not setup or used correctly, then that causes issues. The user often blames the machine when it’s the blade that’s at fault. If the fence isn’t providing good support or the table isn’t perfect extra power will only cover up this to an extent.
More power can mean that the progress through a workpiece can be speeded up, but for a fine finish, the same blade speed through the workpiece produces the same finish regardless of power. Bigger bandsaws have wider wheels and tyres and can support wider blades. As the width increases, more tension is required and more energy is required. So a wide blade requires much more power than a narrow one. A small machine is limited to smaller blade widths and so requires less power. Power is required to cut thicker material and doubling the thickness may require four times the power. A rule of thumb is to use a bandsaw up to 2/3 of the capacity or expect to swap to a low TPI blade. Some blades are thinner which improves lower powered bandsaws.
For cutting curves many things matter, using the right blade, the right tension and using a narrow blade and not using the same blade to also cut straight or expecting it to keep going straight.
The Aldi bandsaw is an example of poor fence (not stable) and an aluminium table (not rigid) which are difficult to overcome (put right). It’s just unrealistic to think that a machine that costs the same as a handful of blades will be perfect.
I suspect that most of the entry level machines overstate their abilities and catch the unwary. One thing to think about is getting spares e.g. most Titan (Screwfix) have no available spare parts. Some items on a bandsaw are easily replaced e.g. the roller bearings because they are universal parts and cheap to replace. The very inexpensive machines don’t have theses parts - not sure where you get these parts. There is going to be a difference in the quality of a 2K bandsaw and one that costs £80 because many things are downgraded or ignored.
The best advice is to try to buy bigger than you think you need or pay up to what you can afford because it’s a very versatile and useful tool. Or expect to move to a bigger/better machine once you know you can justify it.
RichardG":3va0cb50 said:Axminster AC1400B just states 250W which is probably input power which means the output power is more like 150W.
Simon_M":3ngu6gt6 said:I have two bandsaws. One is for sale and the other is new as well as being bigger.
2. A good blade
Register today and take advantage of membership benefits.
