Bandsaw Table Losing Parallel
Ewan C
4 Sep 2021
Sussex
Hi, I have a small Record Power BS250 bandsaw, and the table seems to have a problem staying parallel with the blade, by this I mean that when the fence is attached it’s not parallel to the blade.
I have a bandsaw buddy, which I use to get the fence parallel, but then after I’ve finished with the bandsaw and leave it for a day or two, the fence is un-parallel the next time I use it.
So I have to un-tighten the bolts on the bottom of the table again and get it back to being parallel again.
Anyone know if there is a way to fix this, as I can’t imagine it’s meant to be like this?
Thanks in advance.
MARK.B.
4 Jul 2012
East Yorkshire
Not sure from what you have said but is your fence alignment the problem and not the table:unsure:?.
Jacob
7 Jul 2010
Derbyshire
Band saws often don't cut parallel to the fence after a new blade has worn in a bit. Just a fact of life. You have to work to a line instead.
You might try cleaning the wheels and checking the tension etc.
dzj
29 Jan 2013
Serbia
Perhaps the tires are worn, or your blade is dull or its set is off...
I'd try setting up the fence with a new blade and see how it goes.
Ewan C
4 Sep 2021
Sussex
Sorry for any ambiguity in my post, I thought this might’ve been the problem myself but it’s parallel to the mitre guide slot so I think the fence should be fine?
Ewan C
4 Sep 2021
Sussex
Thanks, I may have been expecting too much from a bandsaw then, although now I think about it I wouldn’t imagine that a thin bendy blade could be very accurate.The tension and the wheels are fine I think.
Ewan C
4 Sep 2021
Sussex
I’ll order a new blade and give that a go, the one I’m using at the moment is the included one, so I’m not sure that they would be the highest quality. Thanks.
Jacob
7 Jul 2010
Derbyshire
Higher tension can make it cut straighter but shortens blade life.
mikej460
19 Jan 2019
Daventry
Do you untension the blade when not in use? I realise that there are contentious views on this but it made be that the tyres are being distorted by the tensioned blade. Try un-tensioning the blade over night and try again.
JSW
22 Jun 2015
Leeds
I have the BS250 also, and had the same problem.
If you're using the stock fence then just bin it and make your own, I did that with mine within 24 hrs of buying it 5 years ago. Incorporate a + or - 5 degree adjustable angle, then match the homemade fence to the Bandsaw buddy. I can take a pic of mine tomorrow if any help, but it's really crude, works though!
And get rid of the stock blade, it's junk, buy a decent one from Tuffsaws and you'll be good to go. Mine is currently running a 1/2" 3TPI SuperTuff Sabrecut as I do a lot of resawing, damn that thing just cleaves it's way through, and parallel every time.
Ewan C
4 Sep 2021
Sussex
Thanks for replying, I do un-tension the blade overnight so should be good there.
Ewan C
4 Sep 2021
Sussex
I think I’ll remake the fence then, and the mitre guide seems terrible too, so I could remake that while I’m at it. I’ll definitely be buying a new blade. Pictures of the guide would be great if possible, thanks.
JSW
22 Jun 2015
Leeds
Well, I said it was crude and it really is! Originally it had a 50mm upstand to the fence, but I found that just got in the way for narrow cuts, so I removed it.
The Fence locks in place with the aid of a Cross Dowel in the table slot.
The pic below shows the bolt and washer removed from the left hand side to reveal the slot for adjusting the angle of the fence. The pivot point is a bit of ali tube hammered through a reasonably tight hole so there's some friction to hold it firm.
I spun the pointy bit of Walnut around also, so you can see it's function.
I really should get around to making a (much!) better version, but it works just fine as is, and there is absolutely zero play in the far end of the fence once locked, which surprised me.
Ewan C
4 Sep 2021
Sussex
Thanks, that looks fine! I’ll make a model in CAD for the templates, and I should have some oak off-cuts the right size, hopefully it’ll finished before not too long. Regards, Ewan.
  • Like
Reactions: JSW
Terry - Somerset
22 Dec 2012
Taunton
Reading this makes me wonder on a few issues:
  • I understand a desire to align blade and fence. But provided the difference in blade and fence angle is less than that created by the kerf on the blade, the blade will always sit in the slot cut by the teeth.
  • One could cut parallel to the edge of a piece of wood with a single point guide. The width of the cut would be the distance between the guide and the blade.
  • A fence only ensures that either (a) when cutting parallel to a straight edge the cut is equally straight, and (b) any inconsistences in the edge of the work piece are averaged (to some extent) by bearing against the length of the fence
  • More important is to ensure that the blade is at 90 degrees to the table so that all cuts are square unless intended otherwise.
  • The fence also needs to be at 90 degrees to the table and of sufficient height so that it can be used as a vertical guide. Probably most important if cutting thin veneer etc where a consistent thickness is critical.
Or is my understanding of these things just plain superficial?
TRITON
5 Oct 2014
Sunny Glasgow
As I understand it, if I understand it exactly, which is infrequent, but here goes anyway...
The table is mounted to the trunnion by 4 bolts. Far as im aware theres play in there so if you loosen off the four bolts, you can waggle the table about and set it up square to the blade via the miter slots, then holding it there retighten the bolts up
JSW
22 Jun 2015
Leeds
As I read it, the OP slackens the tension each night, and RE-tensioning it the next day surely has to alter how parallel the blade is to the fence?
Personally I don't de-tension/un-tension, or whatever the correct term is.
Either way, surely a 10 second adjustment to the fence is far easier than mucking around moving the entire table to suit the blade?
Ewan C
4 Sep 2021
Sussex
Hi Terry, thanks for the reply. The fence is - I believe - parallel to the table. I’ve been loosening the trunnion bolts and realigning the fence but to no avail. The spot guide is something I’ll make for my fence, I’m going to try making one like the one JSW has shared. Regards, Ewan.
Ewan C
4 Sep 2021
Sussex
Hi Terry, thanks for the reply. The fence is - I believe - parallel to the table. The blade is 90 degrees to the table, it seems easier to get this part right. Regards, Ewan.
Ewan C
4 Sep 2021
Sussex
Thanks, I probably will do that instead of adjusting the table, it would just mean that whenever I want to use the mitre guide I would have to get out the protractor and set it that way, rather than using the angle notches built into the guide, although I’m not sure that’s exactly reliable! At least for the cheap plastic included mitre guide.
