Bandsaw setup
A
Anonymous
Guest
Help
I have a new Electra Beckum 316 bandsaw, and with anything larder than a 6mm blade it just will not rip straight.
It either runs out towards the fence or away from the fence and stalls the motor!
I have spent hours on the guides but to no avail
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Mark
There is loads of stuff on the web about tuning a bandsaw. The effects you describe are NORMAL, and you have to learn to work with them. You can mimimise drift, as it is called, by altering the tilt of the top wheel, changing the tension (wide blades need more tension than narrow ones), and your rip fence should be adjustable by a few degrees each way as well.
Try here.
This is one of the pains of bandsaws, you will have to adjust it every time you change the blade.
Steve
Rural Platypus
10 Sep 2003
East Surrey
Have a look here:
http://www.taunton.com/finewoodworking/pages/w00135.asp
Clear step-by-step instructions on bandsaw setup. Assumes you'reinstalling a blade for the first time.
I second Alf's comment on the necessity of a good blade. The ones that come with the machines are nearly always next to useless. The best by consensus seem to be Dure-edge blades.
There is also a very good article in issue 173 of Fine Woodworking: '5 tips for better bandsawing'. After following this I get no blade drift anymore.
Have fun. :p
RP
A
Anonymous
Guest
Mark
My bandsaw did the same and drove me mad until I fitted a Dure Edge blade to it. It no loger wanders at all and tracks dead true even on 9" resawing operations
devonwoody
11 Apr 2004
Paignton Devon
Mark
Been there done that :D
It will come right if you keep at it.
But by choice would forum members who needed to rip a piece of 6"x 2" thick timber go to there table saw or bandsaw?
tim
5 Nov 2004
Herefordshire
Tablesaw, unless you mean ripping along the 6" plane - then obviously bandsaw!
T
gidon
19 Mar 2003
West Dartmoor, Devon, UK
Tablesaw ideally - although mine does struggle with 2" thick hardwood. And if it didn't have one true edge it would have to be bandsaw.
Gidon
Neil
7 Oct 2003
Ireland
Festool plunge saw (yes I really do hate my TS that much :oops: ) - just about possible as depth of cut is 2" with saw on guide rail. Bandsaw if I had one (patience, Neil :roll: )
Cheers,
Neil
dedee
24 Jul 2003
14860, France
Do you mean like this
excuse the dust spots.
Andy
devonwoody
11 Apr 2004
Paignton Devon
Andy
Dedee, That's tight
Do you use KY jelly to get past ? :D
dedee
24 Jul 2003
14860, France
DW,
yes barely 1/4" to spare either side of the tablesaw and only 1" at either end of the wood being ripped. I need a bigger workshop
Andy
