:roll: Has anyone bought a Woodstar SB12 bandsaw? If so you may be able to help me. Looking at the machine from the front, on the adjustable slide that holds the blades supports there are two parallel identical holds. These hold two rods, the left hand one of which carries the screw adjustments and the wheels that support the side of the blade. The right hand one holds the rod that supports the wheel that supports the back of the blade. My problem is that with the side wheels adjusted perfectly when the back wheel is brought up to the back of the blade the rod is actually out of the hole in the slide, so if the blade was "sticky" for any reason it could jam and the whole assembly would then pull violently to the left. The blade is tracking perfectly and cutting perfectly, I can't see there's any other answer than that the rod should be longer (a good 12 mm?) but I can't believe that I'm the only person that this has happened to. I will go back to Woodstar about it but in the interim if anybody can come up with an idea or shed some light that would be really welcome.
sorry, in the second sentence the second holds should read "holes"
