bandsaw help
boschboy
16 Feb 2019
liverpool
record power bs350 any help please just replaced one of the tyres on my bandsaw sent from record power tools tyre is 18mm wide wheel is 23 mm wide does anyone own the same saw and could have a look at there tyres see if the rubber fits full width on the wheel my bottom one is full width help please
Alexam
Bandsaw Boxmaker
27 Nov 2013
Wythall, near Birmingham
I have the BS400 and the tyres fit the wheel. However, it should not make too much difference as the blades are usually running in the middle of the wheel. Why did you only change one tyre, as it is usual to change both to match.
If the other tyre is full width, make a call to Record and just check that they sent the correct tyre, just in case a mistake was made and at the same time, ask if it is OK for just one tyre to be changed?.
