Bandsaw for Metal and Wood, what are my options
Wallaceandsons
23 Oct 2018
Sale
There's a Scheppach MBS1100 around for £200 that will cut steel, but if like a bandsaw that will also cut wood accurately.
Anyone have any recommendations, around the £500ish mark.
Rorschach
Guest
6 Jan 2016
Devon
A bandsaw that will do a great job of wood is far too fast for steel (ok for aluminium and brass), a bandsaw that will do a great job on steel is far too slow for wood unless only cutting very thin stock. You also have the issue that for cutting steel you generally want to use some cutting oil to get the best life from your blades.
Really the best solution is 2 bandsaws. Because I only cut steel occasionally I have a big wood cutting bandsaw and a portaband bandsaw which I modified to fit in my vice along with a small table and mitre slide. Works great.
LJM
27 Aug 2012
Cheshire
A Startrite 14-S-5 has 5 speeds, covering most materials that your likely to want to cut. If you got a 3ph version and fitted a VFD, you’d gain fine speed control within that wide range.
If needed, there’s larger models in the range; they’re fairly commonly available on auction sites and through 2nd hand machinery dealers. They can definitely be had within your budget.
Rorschach
Guest
6 Jan 2016
Devon
+1 to @Rorschach comment. I asked this and addition to speed, swarf in the innards wouldn't do the wheels much good?
The swarf itself isn't the issue, you can clean the bandsaw between changes of material, it's the lubricant you really want to use for steel that then gums it all up inside and the fact you need to change blades often as well.
