bandsaw blades
mailee
26 Jun 2005
grimsby Humberside
does anyone know if Dure Edge have a sight on the internet? I need some new blades for mine and can't find the address.
No they don't.
If you do a search on the forum and you will find their telephone number and address
I used a dureedge new blade yesterday it was a 1/2" blade but has
14 teeth instead of the usual 3 to 6 range.
It made really smooth cuts on some tenon cheeks and shoulders.
Its a pity it takes 10 to 20 minutes to change over blade on a bandsaw :oops:
Thanks guys, I will give them a call and order a couple. Just bought the bandsaw and it came with a spare blade that was kinked the one in it is buggered too so need some new ones. Thaks again guys.
That should come down to a minute or two with practice.
Or was I just used to using a Startrite industrial bandsaw with blade welding built in?. :lol: :wink:
14 teeth to the inch bandsaw blade.
Yesterday I needed a slice (1/4" thick) off some timber to use has a patch to cover a nail hole (second hand timber) the cut was so clean I couldnt tell which side was the sawn or already planed up side.
Just thought I would mention it has in the past using 3 or 6 tooth blades the wood surface looks like a ploughed field.
