Raymond these are current building regs, in the past (I think pre 1992), regulations were less strict. I have seen plenty of stairs with no handrail at all and as long as it was done before 1992 then there is nothing building control can do.
If you need to get the BCO in to certify the stairs then you have a problem because if you have a 115mm gap they will fail.
In which case you have 2 options, redo the job, no too onerous normally as the fillets and spindles are normally easy enough to remove (once you get the first one out). Or add an extra piece to the spindles or an additional finer spindle or wire in the gap.
I have heard that some people put extra pieces in, get the BCO to inspect the stairs, then remove them once he has gone. :shock:
This would only become a problem if the house is sold and the buyers use a particularly diligent surveyor. Or a child with a 112mm head gets it stuck in the rails.
Keith
