The jury's out on the desirability of the proEdge for turning. I know turners who swear by it, but I know turners who won't use one because because they like hollow grinds.
Noho12C":16pqe8si said:…...
(I search for post related to the proedge but didn't find anything.. need to have a second look)
Quite good retrofitting in there !ola c":2otco3zo said:I gave away my Tormek after I purchased a Pro Edge. Had a PMW11 bevel up iron that took forever to grind a new bevel on the Tormek and after that I gave up.
Anyway, I have modified my Pro Edge with a 12mm bar to acchieve some functions (using Tormek jigs) seen on the Axminster version. If the axi was available when I bought my Pro Edge I would most likely have chosen that one instead but I'm very satisfied with mine after the mod, especially helps keeping angles correct when grinding wide plane irons.
Edit. Just remembered I posted those pics before, higher resolution found here post1285977.html#p1285977
