• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Axminster router lift
Sporky McGuffin
Light entertainer
22 May 2015
Headley Down
This is the pre-UKJ version, which means it's a lovely shade of blue, and doesn't have the height lock. The dimensions seem to be identical though. I've not had any issues with it changing position so I'm not sure the lock is terribly important. Includes a predrilled "universal" plate and the height crank with the fine adjustment dial. Missing the spanner doodad to remove the insert ring; I made my own out of a bit of stick and two bolts (pictured), which will be included if you collect, but would be a bit daft to post. Some wear to three corners but otherwise in decent working condition; no issues with the chain assembly.
Open to sensible offers; the UKJ is £349, I was thinking £222 £197 £173 collected from East Hampshire, or plus postage at cost.
Edit to add that postage to most of the UK is likely to be around £8, and that this is up for sale as I'm planning on an Incra router table and this won't fit, so it'll be going towards the Incra lift instead.
Sensible offers considered - or feedback - are these just seen as undesirable? I've had over a decade of faithful service from it and it still works beautifully.
Hi There
Is this still available? If so, how thick is the aluminium insert? What router did you have mounted on it and is it dead flat or does it have a bow?
Many thanks!
