phillimp
Hi all,
I recently purchased a new Axminster radial drill and apart from an initial test when I first put it together I used it for the first time today. I drilled a couple of holes before the electric tripped at the main fuse box. Thereafter the drill would only run for a second or two before tripping the electric. I tried it plugged into a different socket and also without and without an extension lead -however, the same result.
Any ideas? Or is this just a faulty unit?
Thanks, Paul
Thanks, Paul
