RichardG
I’m not having much luck with my Record Lathe, having improved the vibration with a new bearing I wanted to use the Axminster Precision Chuck that came with it only to discover that it has a huge wobble. This is the Chuck.
I removed the backplate from the Axminster chuck which I believe was sold separately to adapt the Chuck to fit different lathes and then checked the runout. Unfortunately I have no way of measuring this but I took a slow motion video.
To compare I fitted a record pin chuck that extends forward by about 125mm so should exaggerate any run out and it looks good so I think the lathe is OK. Is this a fair assumption?
I’ve double checked the the faces are all clean so I can only think this must have been manufactured poorly, shame it says made in England. Is there anything I can do?
