Axminster nailer connector to airline
Rob_H
12 Feb 2005
Hi I just bought an Axminster 15 gauge nailer the AT1550FN 15G FINISH NAILER 15-50MM. I bought a second hand compressor yesterday with hose. Does anyone know which connector I need to join to the airline as it doesn’t seem to fit on the one on the hose. I thought I would pull it back and fit the nailer connector in but it doesn’t seem to fit.
Airline and compressor are fitted with older PCL fittings. Nut on the airline looks to be 1/4 BSP or taper, just remove that and fit the top right fitting with a bit of PTFE tape from this kit.
Sukudon 10 pcs Air Line Connectors Euro Airline Hose Compressor Fittings 1/4" BSP Air Coupler and Plug Kit Couplings Connector Male Female Sukudon 10 pcs Air Line Connectors Euro Airline Hose Compressor Fittings 1/4" BSP Air Coupler and Plug Kit Couplings Connector Male Female : Amazon.co.uk: DIY & Tools
You need to pick a fitting type to use .
Basically , pcl or euro .
Google will show you what's what .
Thanks all - I haven’t used used air tools or a compressor before so all new to me - will try these ideas - thanks
