Axminster nailer connector to airline
Rob_H
12 Feb 2005
Hi I just bought an Axminster 15 gauge nailer the AT1550FN 15G FINISH NAILER 15-50MM. I bought a second hand compressor yesterday with hose. Does anyone know which connector I need to join to the airline as it doesn’t seem to fit on the one on the hose. I thought I would pull it back and fit the nailer connector in but it doesn’t seem to fit.
PDW125
3 Jun 2022
Nottinghamshire
Airline and compressor are fitted with older PCL fittings. Nut on the airline looks to be 1/4 BSP or taper, just remove that and fit the top right fitting with a bit of PTFE tape from this kit.
Sukudon 10 pcs Air Line Connectors Euro Airline Hose Compressor Fittings 1/4" BSP Air Coupler and Plug Kit Couplings Connector Male Female Sukudon 10 pcs Air Line Connectors Euro Airline Hose Compressor Fittings 1/4" BSP Air Coupler and Plug Kit Couplings Connector Male Female : Amazon.co.uk: DIY & Tools
KT -andy
17 Nov 2018
Lincs
You need to pick a fitting type to use .
Basically , pcl or euro .
Google will show you what's what .
Rob_H
12 Feb 2005
Thanks all - I haven’t used used air tools or a compressor before so all new to me - will try these ideas - thanks
