morrisminordriver
Hi, iIm new to turning and have encountered an early problem. I bought a 2nd hand m900 lathe that works fine and invested in a Supernova chuck which is also great. I recently bought a 4" faceplate that screwed nicely onto the headstock , only thing is that anything more than about 6 " knocks against the motor housing at the back! I can see that if I had a faceplate ring that fitted onto the chuck then it,d clear the motor housing as the chuck sticks out a good couple of inches from the headstock. Only problem with that is that i.d need to buy new jaws and ring and discard the screw on faceplate...! Is there anything else i can do?
Thanks, Mike.
Thanks, Mike.
