Glynne
I've just bought a replacement stone from Axminster as they are currently on offer and the difference is amazing.
http://www.axminster.co.uk/axminste...-bench-stone?gclid=CJ7RkvT2pb0CFXMPtAodVysA6w
Before slinging the old away, I was just wondering as to whether I could put it to any use and not knowing anything about the construction of these thought I would ask.
As the stone wears out, is this down to diamond particles being removed from the stone or being worn down (but remaining on the stone)?
If it is the latter, then presumably you might be left with a stone with a finer grit albeit not very sharp for cutting - so perhaps you could use it for lapping?
Accepting that the diagonal lattice structure means the stone won't be completely flat, will it be flat enough for attaching a coarser grit paper for initial shaping / sharpening?
I probably sound like a real cheapskate as the new stone was <£12 but it would be good if I could find a use for the old one.
Thanks,
Glynne
Thanks,
Glynne
